Stock fuel pressure?
Old Oct 6, 2007 | 09:23 PM
gsdz28's Avatar
actually im using the stock pump and a walboro inline pump, what should the fuel pressure PSI be???
Old Oct 6, 2007 | 09:36 PM
dangalla's Avatar
i am sure you can find that info on shoebox's site, thanks again shoebox
www.shbox.com
Old Oct 6, 2007 | 10:36 PM
At idle, vacuum line off the FPR it should ideally be 43.5psi. GM accepts anything in the 41-47psi range. Reattach the vacuum line, and the pressure should drop proportional to intake manifold vacuum, up to 8psi drop with a stock cam, less with a more aggressive cam. Take it out on the road to max RPM/max engine load and the fuel pressure should hold the pressure it was at without the vacuum line at idle. Anything less than 40psi would be a
problem.
If the PCM injector constant was tuned for a higher injector pressure, you have to run it at that level.
DirtyDaveW
Dec 1, 2016 05:37 PM
Cam's maro
Jan 30, 2015 09:21 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
