Stock Fuel P.S.I.
Old May 31, 2005 | 02:13 PM
Evil Eric's Avatar
Stock Fuel P.S.I.
anyone know off-hand what the stock fuel regulator holds the pressure at? im jetting small wet nitrous kit and dont want to shoot it to lean. ive got jets for a 38 psi and a 50 psi system, i searched on here but couldnt turn up anything.
Old May 31, 2005 | 02:17 PM
z2896's Avatar
Re: Stock Fuel P.S.I.
My stock fuel pump is at 42 psi, and it's brand new. The old one was down to 30 psi and it ran like crap. From what I've read on this board, most people keep their LT1s at around 40 psi. Hope that helps.
OBE1 95Z28's Avatar
Stock fuel pressure at WOT (simulate with vacuum line off) is 37 - 43 psi.
Old May 31, 2005 | 02:51 PM
Idle, vacuum line disconnected - 41-47psi.
Put the vacuum line back on, and pressure should drop proportional to intake manifold vacuum. On a stock cam, that might be approx. 8psi drop. On a more radical cam, you might only see 3-5psi drop when you reconnect the line.
At WOT/max rpm the pressure should hold within about 2psi of the "no vacuum" value.
The stock injectors are sized based on a 3 bar (43.5psi) differential pressure between the fuel rail and the intake manifold.
Old May 31, 2005 | 04:38 PM
BUBBA's Avatar
I vote for putting Engineer into the LT1 Tech. Hall of Fame, even before he reaches the 2000 posts.
Old May 31, 2005 | 04:40 PM
BUBBA's Avatar
...make that 20,000 posts.
Old May 31, 2005 | 04:44 PM
Thanks!
Do you realize how many times I have typed that same answer on fuel pressure..... Gotta be at least a hundred times.
Old May 31, 2005 | 04:52 PM
BUBBA's Avatar
At least. The important thimg is your willingness to help everyone out and share your knowledge, even when on many occasions I'm sure you'd like to yell DO A SEARCH DAMMIT!
DirtyDaveW
Dec 1, 2016 05:37 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Catmaigne
Dec 25, 2014 12:16 PM
