Stock Flexplate Weight?
Old Sep 2, 2007 | 04:57 PM
19z28camaro02's Avatar
Question Stock Flexplate Weight?
What is the weight of the STOCK Flexplate on a 96 (4L60E) LT1?
Old Sep 3, 2007 | 11:14 AM
http://web.camaross.com/forums/showthread.php?t=540687
Old Sep 3, 2007 | 11:22 PM
That didnt answer my question. All i want to know is how much the factory one weights.
Old Sep 4, 2007 | 12:18 AM
Daniel6718's Avatar
in that post injuneer posted it weighed 6 pounds
Old Sep 4, 2007 | 05:27 AM
No I didn't. That is the weight for the Meziere.
Problem is, when you multiple post, you reduce the chances of getting an answer. You get confusion just like we have here. That's why we ask that you not post the same question multiple times. I moved the original post to "Drivetrain" because I thought that's where you would get the best chance at a knowledgable reply.
Good luck.
Old Sep 4, 2007 | 09:58 AM
The first post didn't answer my question and this one has yet to do that also. I searched the archives and found no answer. All I want to know is what the stock flexplate weights on my car. I don't want to take it all apart to find my answer.
Old Sep 4, 2007 | 02:28 PM
JAKEJR's Avatar
How exact do you want the weight?
I have a stock flexplate in my storage locker that I removed from my 96 LT1 Vette. I can take it to the PO and weight it if it's REALLY important to you. Bit of a PIA, but I'll do it for you if you REALLY need to know and if no one else comes up with the weight for you.
Let me know.
Jake
Old Sep 4, 2007 | 11:23 PM
x.xx pounds would be good. I'd just hate for u to go through all that trouble though
Old Sep 5, 2007 | 01:13 AM
JAKEJR's Avatar
Okay, I beat you to the punch. I went to the locker and picked it up. On my bathroom scale it weighs slightly less than five pounds, but we know how inaccurate those scales can be.
So later today I'll weight it at the post office and post the results.
Jake
Old Sep 5, 2007 | 05:16 AM
rskrause's Avatar
Moderator
Just curious, but why would you want to know this? Just curiousity?
Rich
Old Sep 5, 2007 | 09:31 AM
Replace the stock flexplate with a lighter one? it would be done for the same reason as a lightened flywheel. You'd be lowering the weight of something attached to the motor, therefore, the motor would do less work to reach higher RPM, THUS, quicker acceleration in RPM, more than likely resulting in a quicker acceleration in MPH
Old Sep 5, 2007 | 02:24 PM
JAKEJR's Avatar
Just returned from the Post Office.
Stock, 1996 LT1 flexplate weighs 4 lbs., 13.20 oz
Hope this helps.
Jake
Old Sep 5, 2007 | 06:02 PM
chief455's Avatar
Reducing rotating mass weight is great for freeing up useable hp and quicker rpms. But never at the expense of strength.
By going from just under 5 lb stock to 6 lb SFI approved - you are 1 lb more insured that your high powered engine won't destroy the flexplate.
Reasearching this was a great idea but it proved to me that the aftermarket plates are not too heavy as to reduce power by any noticeable amount.
Old Sep 5, 2007 | 07:24 PM
Daniel6718's Avatar
true i have sen stock flexplates crack
Old Sep 5, 2007 | 08:23 PM
So We Have Our Answer, Halleighluya!
