stock crank and rods???
Old Dec 9, 2003 | 06:18 AM
1badasZ's Avatar
im thinking about going ahead n taking my short block out while im waiting on the heads n cam n converter. mainly to replace the bearing and rings. while i have it out i might as well go ahead n put some forged pistons in it and what i wanted to know is, how strong is the stock crank n rods? i wont be making a whole heap of power but what power and rpm are they good to. i want to go with the 847 cam so will i be able to rev high enough to get the best it has to offer? ill be going back with ARP everything. just trynna make a good combo on a budget but dont wanna build a bomb either
Old Dec 9, 2003 | 07:15 AM
my94blackz's Avatar
i dont think many ppl kno all bout this subject the rods are supposed to be exelent for strength but what i needed to kno was weight. as for the crank i didnt really get a str8 answer on that either.
Old Dec 9, 2003 | 07:57 AM
Camaro_Maniac63's Avatar
If you get the rods and the crank reconditioned, you should be OK. The stock rods and crank are pretty damn strong, and as long as you have everything balanced, you will be fine. Good luck.
canbaufo
May 25, 2015 12:01 PM
Noer
Feb 28, 2015 11:29 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Queens94z28
Nov 20, 2014 06:03 PM
