stock crank question
Old Jul 7, 2010 | 01:26 PM
97ramairta's Avatar
Im thinking about building a 355 with the stock crank, forged rods, and forged pistons. what would be a safe rev limit for this setup? 65-6600? Im wondering bc this is going to be the deciding factor for the cam and what duration to run. Thanks
Old Jul 7, 2010 | 02:30 PM
rclearyiii's Avatar
Depends on a few factors such as: What type of springs are you going to run, lifters, rockers...etc... Are you going to get the rotating mass balanced?
Old Jul 7, 2010 | 02:44 PM
97ramairta's Avatar
the rotationg assembly will be balanced, i will be testing out the new Alex Part dual springs, 1.6 rockers, chromoly pushrods, LS7 lifters
Old Jul 7, 2010 | 02:45 PM
97ramairta's Avatar
im mainly just wondering if the stock crank is good for reving to 65-6600.
Old Jul 7, 2010 | 02:50 PM
RamAir95TA's Avatar
I've seen the stock crank rev to 7k and beyond, easy. Go for it.
Old Jul 7, 2010 | 03:15 PM
rclearyiii's Avatar
Agree..have seen a stock crank hit 7000 many times.
Old Jul 7, 2010 | 03:16 PM
slomarao's Avatar
Ive heard of people turning 7500 rpms / 750 flywheel HP on a stock crank.
Also on the list of the fastest LT1's theres a guy running 9.7x @ 138ish ( i think) who runs a 300 shot on a stock crank 355.
I wouldnt lose any sleep going to 500rwhp or 7k with it. Balance the shortblock, go 4 bolt main for the hi rpms.
Old Jul 7, 2010 | 06:11 PM
97ramairta's Avatar
exactly what i wanted to hear. thanks guy
Old Jul 7, 2010 | 07:41 PM
rskrause's Avatar
Moderator
It will be fine IF it's in good shape. Have it Magnafluxed to be sure.
Rich
Old Jul 7, 2010 | 09:03 PM
97ramairta's Avatar
it should be in good shape. its got 116K on it...it was a fine running motor and was only removed bc the car got tboned...its outta one of my cars from a few years back
Old Jul 9, 2010 | 12:16 PM
PWR SHFT's Avatar
Yeah, but do the due diligence. Like Rich said, have it magnafluxed and checked for straightness. FWIW, I am doing the same thing shortly.
HectorM52
Jul 30, 2017 11:46 AM
cmdeshon
Dec 27, 2014 10:06 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
