Stock crank
Re: Stock crank
Stock crank may technically be cast but it is incomparably better than aftermarket cast. I would put it against the chinese forged cranks like Eagle and Scat. Been playing with this car for a decade and I am as of yet unaware of anyone overpowering the stock crank.
Stock parts can take a couple hundred hp more than stock before you have to worry.
Re: Stock crank
Re: Stock crank
That is blind bashing for the most part. Half of them claiming 350hp was risky when the LT4 was fractured cap PM and 330 factory and a LOT of us run over 450hp on stock shortblock.
I am not saying the PM stock rods are great, but they are better than folks without experience assume they are.
My first junkyard shortblock spun a bearing, the bearing went away entirely and the rod bent but never broke.
Re: Stock crank
I do not disagree other than to say I would go to a $300 capscrew rod, BUT my point was more that folks jump on the rebuild bandwagon WAY too quickly when stock parts can serve them better than the cheapest aftermarket stuff they tend to buy.
Brandon Wittmer
Dec 20, 2014 09:51 PM
