stock cc head?
Old Aug 11, 2007 | 05:54 PM
Spudz's Avatar
stock cc head?
whats the size of the chamber on the stock heads? and are standard sbc 350 pistons the same as lt1's? I am thinking of going with keith black .30 over...
http://www.jegs.com/webapp/wcs/store...10002_89328_-1
Old Aug 11, 2007 | 06:11 PM
96z28t56's Avatar
i belive their either 54 or 52 cc's
Old Aug 11, 2007 | 06:34 PM
Stl94LT1's Avatar
You looking for a 12:1 compression ratio. If so, those pistons will get you there.
Old Aug 11, 2007 | 09:23 PM
Z-RATED94's Avatar
Some say 54cc, and some say 58cc? I thought Lloyd said mine were 54cc.
Old Aug 11, 2007 | 10:43 PM
Spudz's Avatar
ehh I think 12:1 is a bit high, especially for premium pump and stock 29k bottom end.
any suggestions then? highest I can go, on pump fuel.
Old Aug 11, 2007 | 10:51 PM
lethal93ta's Avatar
I did 3 sets of LT1 heads so far and all 3 were right around 54cc.
Old Aug 12, 2007 | 07:19 AM
Z-RATED94's Avatar
Do some research. If running a big cam you can run a higher static compression ratio than stock. To much to explain here on how it works. The short of it is that longer duration cams bleed off some of the compression.
Catmaigne
Dec 25, 2014 12:16 PM
isimplyexist
Mar 25, 2004 08:06 PM
CobraEatr
Jul 29, 2002 11:46 AM
