stock block on a 383 stroker?
Old Oct 20, 2003 | 01:49 PM
wayne97's Avatar
should i use my stock block to build my 383 stroker? its going to be in the ballpark of 400hp/400tq. also ... will ls1/ls6 injectors work on my lt1?
Old Oct 20, 2003 | 01:59 PM
Do you mean use your stock block without any reconditioning? As a minimum, have it tanked, and examined for cracks, then bored, and clearanced for the 383 crank. Have the mains checked for alignment, and align bored if not up to spec. A 4-bolt conversion is not necessary at the HP levels you are looking at.
An LS1/LS6 injector will "work" in your LT1, but you won't gain much of anything. The LS1/LS6 injectors are flow rated at 58psi, and will flow 13.6% less than rated when used at the LT1's 43.5psi. If you aren't going over 400 "flywheel" HP, you could get by with the stock 24# injectors. If you mean 400rwHP, you might want to consider 30# injectors.
Old Oct 20, 2003 | 02:08 PM
wayne97's Avatar
Fred,
Thanks for your help. You answered everything I needed to know. If anyone else has any input let me know ....
Old Oct 20, 2003 | 02:24 PM
One "helpful" hint, based on some of the problems I've seen posted recently..... be sure they clearance the block for the crank BEFORE they do any other machine work. There have been a couple people posting problems with shops grinding through the water jacket, on a block that has already been fully machined. Makes it a much more expensive "repair".
Old Oct 20, 2003 | 05:15 PM
JONEZ_Z's Avatar
Is there a lot of clearancing nessasary with a 383? How much clearance should you have between the block and crank/rods?
Old Oct 20, 2003 | 05:30 PM
RCF925's Avatar
.060 clearance crank to block to be on the safe side
Old Oct 25, 2003 | 12:06 PM
Lt1tko5o's Avatar
Just clearanced a block this spring for a 383, didn't take much work at all with the dremmel.
Make sure you have the .060 clearance like they discussed above.
Brian
D1SC383LT4
Jan 1, 2016 01:56 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Killer94z
Jan 13, 2015 12:06 PM
spearous
Jan 12, 2015 11:03 AM
