Stock Battery Guage reading 12-11amps Alternator Problem?
Old Oct 18, 2003 | 04:25 PM
boxerfreeflow00's Avatar
well the stock guage is reading around 12-11amps
its in the dotted red area
i just replaced battery
alternator problem?
not charging battery?
any ideas thanks
Old Oct 18, 2003 | 04:57 PM
Terran2k's Avatar
i assume you mean 11-12 volts. use a DMM and check it at the battery terminals with the car running. see if its the same as u see on your dash. If its low with the DMM take it to Autozone, I believe they'll test your battery and alt for free.
Old Oct 20, 2003 | 09:08 AM
IDOXLR8's Avatar
I am having the same issues. I ended up replacing my alternator and it still does it. If I check the voltage at the alternator is show that it is charging ok but my gauge is off.
Old Oct 20, 2003 | 09:17 AM
Van5150's Avatar
I too had low voltage. I changed my serpintine belt and gained 4 volts. I didnt think it was that worn out, but whenever I had to remove and reinstall my old belt it was very easy. My new belt I got was very tight, I had to pull hard on that belt tensioner to get the belt on. I knew at that point before even starting the car this was my problem.
DirtyDaveW
Dec 1, 2016 05:37 PM
Gtpguy
Jan 26, 2015 04:50 PM
Zomie
Sep 2, 2002 09:04 PM
ur2slo50
Aug 30, 2002 10:45 PM
