Stock 94 timing chain
Old Oct 16, 2005 | 07:46 AM
Honda Hunter's Avatar
Did a search but didnt find what I was looking for. My question is what is the stock timing chain rated to, when should it be upgraded. Also what are some good stock replacements? LT4 timing chain is a last option due to everything that must be changed with it.
Old Oct 16, 2005 | 08:37 AM
sssalah's Avatar
Re: Stock 94 timing chain
One of the benefits of changing to a vented opti is the ability to run a better timing set. The regular LT4, extreme duty LT4 requires changing to vented opti, a nice double roller with an electric water pump requires it as well.
The most envolved part of the conversion is the cam dowel pin length, you're still covered on that regard
Old Oct 16, 2005 | 08:40 AM
Well then that settles it. Now I just need to find out where I could get it cheapest Dal or Jason Cromer.
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
