still more LT1 problems!
Old Jul 14, 2008 | 08:07 PM
97SS0594's Avatar
in the 97.. replaced bent valves timing set ect... before we replaced the valves we thought it was just the timing set, after i replaced it car started and idled, it ran like crap but still ran. I then discovered 3 bent valves only on 1 side (drivers) removed head and had valves replaced at a machine shop. installed the head plugged everything back in and had no spark. replaced the ICM and the coil, also just did the opti test and everything checks out. i also tried another computer also still no spark. what the heck could i be missing?
Old Jul 14, 2008 | 08:14 PM
seawolf06's Avatar
Did you get any spark from the opti to the coil?
Old Jul 14, 2008 | 10:37 PM
tlillard23's Avatar
From the opti TO the coil? I thought it went from the coil to the opti? (no I am not being a smart-A)
Sounds like you need to recheck your connections. I bet you forgot to plug something in.
Old Jul 15, 2008 | 05:16 AM
97SS0594's Avatar
coil is not fireing, but im getting a signal to the ICM. this is frustrating.
Old Jul 15, 2008 | 08:18 AM
seawolf06's Avatar
Between the two, my bad.
Try changing to another coil. I received one from MSD that was DOA. They're all made the same exact way, so get the cheapest one you can find that isn't reman.
Old Jul 15, 2008 | 01:52 PM
97SS0594's Avatar
ill have to do a test on the coil, it is brand new if its DOA ill be hot!
Old Jul 15, 2008 | 10:03 PM
97SS0594's Avatar
got the car started! the optispark was bad... sortof, the opti guts where very very coroded, so i put my spare on and she fired right up! now to change the oil like 3 times to make sure theres no water in the oil!
InfernalVortex
Jan 17, 2015 09:35 AM
1LEThumper
Jul 14, 2003 12:45 PM
JSK333
Sep 9, 2002 10:33 PM
smacz28
Aug 6, 2002 01:51 PM
