Still got an Oil Leak!!!
Old Sep 12, 2008 | 05:46 PM
lt1stroker's Avatar
Ok so my cars been leaking everytime i drive it, when it sits, it wont leak. I got the car up and the oil is coming directly under the engine. It comes on the front sway bar and a little metal sheet behind it. Does anyone know what it could be, i changed my intake gasket about 4 months ago. Help
Old Sep 12, 2008 | 05:56 PM
red 95 z28 lt1's Avatar
timing cover, wp seal, opti seal, crank seal, they would all leak when running, remove your throttle body and see if the top front of the block is dry then you know for sure its not the intake again, check oil cooler lines too
Old Sep 13, 2008 | 10:37 PM
lt1stroker's Avatar
I checked the block and it is dry. The oil seems to come from the passenger side of the block. It seems to leak alot too. I have a buyer for my car and i dont want him complaining. Any help diagnostics i can do?
Old Sep 14, 2008 | 12:22 AM
lt1stroker's Avatar
Anybody? Injuneer?
Old Sep 14, 2008 | 12:25 AM
briggsbuilder's Avatar
wash the bottom of the car really clean..... then start the car and go around the block real fast.... park it and since u have clean up the engine u will directly be able to see the fresh leak...
so clean bottom of engine...
drive car............
look at the bottom to pinpoint the leak...............
Thats the way i always do it
Old Sep 14, 2008 | 12:42 AM
if its leaking from the passenger side of the block the only thing i can think of is the valve cover on that side
Old Sep 14, 2008 | 12:50 AM
klrz28's Avatar
Whos doesnt leak ??
Old Sep 14, 2008 | 01:22 AM
lt1stroker's Avatar
alright koo.
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
