Steerng shaft question
Old Jun 10, 2006 | 12:45 PM
MeenZ28's Avatar
How do you disconnect the steering shaft? I'm having a little trouble with my header install and if i can just get that thing outa the way temporarorly than i wouldnt be haveing such an hard time. But I dont knwo how to go about that and moreso i dont want to do any damage to the steering. Any help woudl be apreciated.
Old Jun 10, 2006 | 12:59 PM
wrd1972's Avatar
Re: Steerng shaft question
Remove two bolts (13mm I think) , one on the top op the shaft and one down on the bottom. You may need to rotate the steering wheel to see them.
Then pull the shaft off of the steering gear then slide it off the steering column shaft.
Spray some PB blaster on the ends to help if needed. This is easy to do with nor risk period plus the shaft will only reattach one way so it is near impossible to put it back on wrong.
Old Jun 10, 2006 | 01:32 PM
Bud M's Avatar
You do have to actually remove the bolt on the lower end to get the linkage off
Be sure not to turn the steering wheel while the linkage is off or at least mark the shaft and linkage so you reinstall it right
Old Jun 10, 2006 | 02:08 PM
96ZCamaro's Avatar
Make sure to have a screwdriver to pry on it. And I beleive the size is 11mm for both bolts. Get the bottom part out first then just pry out the top part. Little bit harder getting it back in somtimes.
Old Jun 10, 2006 | 02:35 PM
MeenZ28's Avatar
That was cake! Thank you so much guys for your advice. Got the linkage off and the header is on! GM did not make this job easy on us did they? LOL But thanks again all of you. For technical questions I know i can always rely on my friends at CamaroZ28.com!
Old Jun 10, 2006 | 03:41 PM
Sinister95Z's Avatar
How about some progress pics over at PC.com Grant??
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Victor Lamb
Aug 26, 2017 02:52 PM
canbaufo
Parts Wanted
Feb 21, 2015 11:51 PM
importkiller94
Jan 17, 2015 09:03 PM
importkiller94
Parts Wanted
Jan 17, 2015 07:23 PM
