Steering shaft hitting header
Old Oct 17, 2003 | 09:51 PM
$hawn's Avatar
The thin metal clip things on the shaft that are rivited to the rag joint, that point upward, rub the second tube, I already bent them inward but there still rubbing. Is there anything else I can do, or do I need to snip the part where it starts to point upward?
Old Oct 17, 2003 | 10:07 PM
Z95m6's Avatar
what headers do you have? I am jw i have heard about this a lot on MAC's.
Old Oct 17, 2003 | 10:49 PM
LWM's Avatar
LWM
For AS&M headers, some teething problems can be encountered. The #1 header tube (the removeable one) can hit the steering shaft at WOT. Cure was to move the steering collar up about 1/3", no more rattling of the steering gear. You will need a pry bar to move the collar up, and a buddy to tighten the collar back down while you are holding the collar in its new position.
Doing this actually moves the entire shaft about an 1/8 of an inch and that should be enough.
Hope this helps
LWM
Old Oct 17, 2003 | 11:24 PM
$hawn's Avatar
I have the jet hot long tubes, the removable tube(#1) isnt anywhere near the shaft, just the 2nd tube, I cant move the shaft up cus it'll be up more into the tube, think all I have to do is cut those thin pieces off, but not sure if it will have any adverse affects.
Old Oct 18, 2003 | 12:09 AM
CoUnTryMuZiCZ28's Avatar
I have MAC headers and the steering thing hits alittle... well it did.. I got a metal rubber rag joint and was goin to deal with the hitting problem but the problem fixed when i put the rag joint on.. it moved it alittle more than an 1/8 of an inch over...
Old Oct 18, 2003 | 10:21 PM
$hawn's Avatar
Does any think if I just snip off that metal piece, it'll be ok?
Old Oct 18, 2003 | 10:34 PM
I wouldnt snip any thing off.. If you want to spend money down the road.. why dont you just shave it down alittle with a dremel???
Victor Lamb
Aug 26, 2017 02:52 PM
4586
Mar 18, 2015 06:31 PM
importkiller94
Jan 17, 2015 09:03 PM
CaRParts102
Dec 6, 2014 08:45 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
