Steampipe seal alternative?
Old Apr 18, 2005 | 03:27 PM
  #16
sssalah's Avatar
Re: Steampipe seal alternative?
I got similar seals from an AC hardware store and fixed them on the impy when the engine was out more than a year ago and they're holding very well. They were about $2 a piece, and they're a little bit smaller than stock. Only reason I got them is becuase the local dealer only sells them with the pipe and bolts for $115.
Old Apr 18, 2005 | 03:32 PM
  #17
89305rs's Avatar
what kind of seal were they?
Old Apr 18, 2005 | 03:34 PM
  #18
93black-ta's Avatar
gm parts direct has the right seals for only $3.55 ea.i just bought four myself
Old Apr 18, 2005 | 10:18 PM
  #19
97 6SPEED Z's Avatar
Thumbs up Re: Steampipe seal alternative?
Okay, I'm in the middle of a head swap right now so I can tell you with absolute certainty, (because I just measured one!), that those seals measure 1.100" O.D. and .450" I.D. They must be Metric, but these are the English (i.e. inch), dimensions. I found and almost identical washer/seal at AutoZone in their oil pan drain plug gasket kit, (which they keep behind the counter), and bought four(4) of them at 99 cents each! Total paid with Tax was like $4.20 for all four seals and yes, the local Chevy dealer here in Michigan wanted like $5.44/each for these things??? Try your local AutoZone for these things.
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
colts0455
Sep 27, 2015 01:07 PM
tommalcolm
Sep 11, 2015 03:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
