Low RPM slight surge
Old Jul 18, 2010 | 04:28 PM
Bobsep84's Avatar
Hey guys, I have been noticing lately a light surge when driving at a very low RPMs and very light throttle. This started happening after replacing the head gasket and adding headers to the car. The car drives/accelerates fine otherwise...it also seems to only happen once the car is in closed loop and does not happen when cold. Iv had this happen years ago in the past and it turned out to be a failing fuel pump...but i don't think that is the case this time. Any ideas?
Old Jul 20, 2010 | 11:56 PM
Bobsep84's Avatar
Connected up my scan tool today and noticed my MAP sensor reads 4.75 volts when the car is off and about 1.20v with it idling in park. Does this sound right?? Also...the p/n on my MAP sensor is 039-4220...is this correct for a 95 LT1??? Also the map reading shows 27.9 Hg with the car off...this doesn't seem right being im at a low elevation....im really confused
Old Jul 22, 2010 | 11:33 AM
GRIDERMAN87's Avatar
check your O2s man the headers coulda burnt them up it will make the car run rich and miss at low rpm
timmy39120
May 8, 2015 11:41 AM
Noenav
Apr 30, 2015 01:06 PM
edman
Jan 22, 2015 02:45 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
