Steam Line
Re: Steam Line
Depends on the year of the F-Body, but there is no surge pot.
1993-94 it goes to a connection on the radiator end tank, right under the radiator cap.
1995-97 it goes to the coolant connection on the bottom of the throttle body.
Check the diagrams (#16 and #18) on Shoebox's page:
http://shbox.com/1/drawings_exploded_views.html
Re: Steam Line
On the b-bodies it goes through the TB then to what you are calling a suge pot but it is actually a circulating part of the system and is where the pressure cap is located. We usually bypass the tb and run it right to the tank.
