Starts and then dies
Old Apr 9, 2003 | 02:16 AM
thebigdog's Avatar
Unhappy Starts and then dies
I recently installed new motor (used 95 lt1) motor and ECM. The motor starts and then dies, I have fuel pressure, oil pressure, and when I un plug the MAF it does the same thing, anyone got any ideas?
Old Apr 9, 2003 | 02:31 AM
MZK4252's Avatar
Could be air or fuel related. I would suggest: check injectors, monitor fuel pressure long term, check compression, and check out IAC valve and TPS.
Just some ideas...
Old Apr 9, 2003 | 10:23 AM
fbird95's Avatar
I had a similar prob;lem when the car was hot and sat for 20 minutes. Turned out to be a evap canister hose rotten. I doubt that this will help you though.
Old Apr 9, 2003 | 10:27 AM
For starters, make sure you have not left any vacuum hoses off, you have power to the MAF, intake elbow is not ripped or not on properly.
Old Apr 10, 2003 | 12:22 AM
thebigdog's Avatar
Thanks for the ideas, but I found the problem, the guy had his ECM reprogrammed and failed to program out the VATS.
Changed ECM's and viola...it lit and ran!!!!
Old Apr 10, 2003 | 12:46 AM
turbo_Z's Avatar
mine did this and i was getting opti codes. after replacing the opti my problems has disappeared.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
A's 91 Z28
Jan 11, 2015 10:58 AM
Ricardo
Nov 29, 2014 10:58 AM
