Starting Troubles
Old Aug 26, 2004 | 07:57 AM
White96Z's Avatar
Question Starting Troubles
I have been having trouble getting my 96 Z to start lately. It seems to happen most after it sits for a day or two. The engine will crank and crank, but will not fire. Fuel pressure at the rails is good. Spark at the ignition coil is good (haven't checked a plug yet). Sometimes it will try to fire and will sputter for 5-10 sec when I stop cranking. It almost acts as if it's flooded believe it or not. If I pull off the intake, open the throttle body and let it air out for a while (about 30 min) it will start. It runs just fine and will then start easily until it sits for a while again. I threw a code the other day which was a 0410 Secondary air injection malfunction. I don't know if the two are related, but if anyone has any ideas on what could be causing the problem please give me your input. Thanks.
Old Aug 26, 2004 | 12:33 PM
White Knight 95's Avatar
Re: Starting Troubles
Can the injectors fail open? This would cause leakage and possible flooding.
Old Aug 28, 2004 | 10:18 AM
White96Z's Avatar
That's what i've labeled suspect. Either that or the fuel rail is leaking. I got the car started Thursday and it's been running fine ever since. It seems that the longer it sits the harder it is to start. Sounds like something's leaking fuel down into the cylinders and flooding it out. Can the injectors stick open if they're dirty? Can the fuel rail leak into the intake manifold?
DirtyDaveW
Dec 1, 2016 05:37 PM
armedtrigger
Feb 24, 2015 08:30 PM
warmeck
Feb 2, 2015 12:44 AM
David Dorris
Jan 17, 2015 08:10 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
