Starting Problems
Starting Problems
From time to time I have problems starting the car. My thinking is that the headder is cooking the start. I am still on my first starter but when I drive it awhile and it comes to temp it is hard to start after a couple tries it will fire up when you turn it off
But I have also with it setting I drive it to work it set all day then went to start it and all I got was the dreaded clicking but after three or four tries it started up.
Any ideas of what is causing this?
Re: Starting Problems
Dirty/corroded/burnt contacts in the starter solenoid. Pretty common. A rebuilt starter is the easiest solution. Sometimes you can take the solenoid apart and rotate parts to get clean contact areas but it does take some knowhow.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
