starting problems
Old Mar 16, 2007 | 03:57 PM
shinerscamaro's Avatar
starting problems
i have a 94 z28, it recently started having hard starts, it takes about 8 seconds to start. It just keeps turning over and finally kicks. A hard turn now a weak one. i recently changed out the plugs, fuel filter and wires. I still have the problem, any suggestions???? is it the starter? please pm me?
Old Mar 16, 2007 | 04:03 PM
mrmint69's Avatar
Just check the fuel pressure. Its the easiest way to eliminate that. It may be a weak battery or something went wrong with your tuneup.
Old Mar 16, 2007 | 04:07 PM
2000GTP's Avatar
The fuel pump check valve is a pretty common thing to fail and can lead to hard starts. Shoebox has a writeup on how to check your fuel pressure: http://shbox.com/1/4th_gen_tech2.htm...essure_testing Once you put the key in the run position, the fuel pressure should jump and and remain steady. If it bleeds down rapidly, then you have a problem. Also, leaky fuel injectors or a faulty fuel pressure regulator can be an issue as well.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
