changing valve springs
Old Mar 16, 2007 | 04:10 PM
95LT1conv's Avatar
im going to be chaging my springs soon w/ heads on. would i be wrong in assuming i could do the swap the same way as a valve adjustment? what i mean is, can i bring #1 tdc and do all valves that are closed and then rotate the crank and do the rest of them? seems like it would save time over bringing each cylinder to tdc seperately.
Old Mar 16, 2007 | 04:14 PM
2000GTP's Avatar
You need to know what cylinder you are bringing to top dead center and that method will work as the piston will act as the support for the valve. Shoebox, as always, has an excellent writeup outlining the procedure: http://shbox.com/ci/valve_spring_swap.html
nikolt1
Feb 27, 2015 09:10 PM
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
