starting problems
Old May 8, 2006 | 09:27 PM
jamilz28's Avatar
starting problems
ok my car sometimes doesnt start the alt is good i had it tested and the battery is at 100%
when the car is off is at 12.5 volts when the car is starting it gets down to 7.2 volts and when is on its at 14.4
is that normal?
Old May 9, 2006 | 05:29 AM
Guest47904's Avatar
Guest
Re: starting problems
Not sure how you tested the battery but it's either severely under rated from what it should be or it's shot. If it was used at one time to start the car ok, it is now shot. No battery should drop below 11 volts when cranking. A defective starter will cause the voltage to drop and crank slowly but it can't go that low on a good battery.
You may also have a bad starter but I know you have a bad battery.
Old May 9, 2006 | 11:34 AM
jamilz28's Avatar
thats what i told my dad but he didnt think that i was right
thanks
Old May 9, 2006 | 11:42 AM
jamilz28's Avatar
can auto zone check if its the starter and the battery
Old May 9, 2006 | 09:22 PM
jamilz28's Avatar
the battery says its 315 amps is that enough
Old May 9, 2006 | 10:16 PM
Dave89IROC's Avatar
is that CCA ?, or CA ?
either way, I'm surprised it starts
Old May 10, 2006 | 04:29 PM
jamilz28's Avatar
so its way too low?
if it is should i get an optoma red top
Old May 11, 2006 | 05:13 AM
Guest47904's Avatar
Guest
so its way too low?
Sounds like a lawn & garden battery. Should be 600 or above.
Don't get an optima battery unless you have a charger that can handle it. Conventional chargers will not work correctly.
Old May 11, 2006 | 04:13 PM
jamilz28's Avatar
i got it wrong it is a cca 630
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
