starting problem
Old Jul 10, 2005 | 06:16 PM
ReptileZ28's Avatar
starting problem
I'm having a problem that started off with hot starts but now the car is hard to start at all times. It gives the syptoms of a dead battery and the car will start with a jump pack. The thing is the battery tests at 12.5v. When the car is trying to start the voltage drops as low as 6v. Does this sound like a battery going bad or a starter going bad?
Old Jul 10, 2005 | 06:59 PM
slopokrodrigez's Avatar
Re: starting problem
Start with the battery unless you can measure the current to the starter. But chances are it's the battery. You can always swap in a battery from another vehicle temp.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
