CSR water pump install
Re: CSR water pump install
You will need to cut out some notches for the csr to fit. I only have mine hooked to ground and to a source for key on power. But I guess hooking to a relay wouldn't hurt.
Z
Z
I used ken lowrance's guide when I installed mine a few weeks ago. I didn't wire up the switch however. Use the relay and fuses if you care about the wiring. You will need to notch the fan housing and get a new intake elbow, 1LE or vortech etc. I havn't got mine yet so I've just got tape over the hole for the silencer tube. The silencer must be removed as it won't clear the pump. I'm eager to get the 1LE elbow as I don't trust the tape for very long.
stockssn2o
May 25, 2015 08:54 AM
