starting problem
Old Apr 8, 2004 | 01:32 PM
st08x's Avatar
starting problem
car doesn't start, everything turns on but the starter does nothing, makes no noise, it is getting power, changed the starter nothing, need help quick! what else usually goes bad, has 103,xxx miles
Old Apr 15, 2004 | 05:36 AM
slopokrodrigez's Avatar
How old is the battery? Don't assume that because you may have had it on a charger for sometime, that it's good. Have you load tested it lately? Check the voltage accross the battery before you try to start it and during cranking the starter. Obviously you will need help with that.
If the voltage is less than 11 volts when you crank the engine, you will need a new battery. Check the ground at the frame and the engine for cleanliness.
Once you have a KNOWN good battery installed, with the engine running, you should read well over 13 volts across the battery. This will indicate the alternator is working properly.
Old Apr 15, 2004 | 09:03 AM
sabre81's Avatar
if your battery is good, its probably your ignition cylinder. its no longer reading your key which causes this no start condition. I had to replace mine about a month ago. COmes with 2 nice new shiny keys also
good luck
Old Apr 15, 2004 | 12:46 PM
st08x's Avatar
good luck
that's exactly what it was, thanks for the reply
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
