Starting New engine ?
Old Mar 8, 2005 | 03:24 AM
unTAmedLS1's Avatar
How do u get oil everywhere before starting your fesh motor... its not like we can pull the distributor to turn the oil pump shaft so is there another way?
I have a fresh 383 build that should be in car ready for starting this weekend but IM wondering how I can prime it up.
Thanks in advance
EDIT* Nevermind i havent put intake on yet so ill just do it the old drill fashioned way but is there anything else I should look at other than the obvious...Im just afraid that i messed somethin up putting it back together even though i went through it over and over again...
Old Mar 8, 2005 | 03:37 AM
nateh's Avatar
Re: Starting New engine ?
I pulled all the plugs and spun it with the starter for a bit. You can spin the engine with no compression and it won't damage the bearings. I have headers with good plug access, so replacing the plugs didn't take too long. After I got the plugs and wires back on, I pulled the coil wire and the fuel pump fuse and cranked for a few seconds to make sure pressure was still up. It was, so I replaced the fuse and coil wire and started it.
Old Mar 8, 2005 | 08:00 AM
GetaZforgetGT's Avatar
A lot of people just pull the fuse for the injectors.
http://web.camaross.com/forums/showt...priming+engine
Old Mar 8, 2005 | 08:33 AM
Ken95Z28's Avatar
I have always primed mine before I put the intake on it. There is a tool that you can get that attaches to a drill motor to spin the oil pump. But if your intake is already on than I suggest what they said above.
Alex Barnes
Jan 24, 2015 10:21 PM
HCz28
Jan 11, 2015 11:21 AM
A's 91 Z28
Jan 11, 2015 10:58 AM
97z28k&N
Jan 9, 2015 04:58 AM
Jul 4, 2005 05:00 PM
