How much spring pressure can a hydraulic lifter take?
Old Mar 7, 2005 | 08:41 PM
Mikey97Z's Avatar
Question How much spring pressure can a hydraulic lifter take?
I'm wondering if I have collapsed lifter problems caused by too much spring pressure. The open pressure for the 977 springs is 420 lbs. Is this too much pressure for a hydraulic lifter?
Old Mar 7, 2005 | 09:31 PM
Mindgame's Avatar
Re: How much spring pressure can a hydraulic lifter take?
That may be pushing things a little. A hydraulic lifter will function with roughly 160 lbs (closed) and ~400 lbs over the nose but to take any more than that requires lifter modification. Basically running it like a solid with very little plunger travel.
Running your 230/236 XE, I'll say back off on the spring.... 150 and ~380 (fresh spring rate) would likely be more than adequate.
How did the lifters fail?
-Mindgame
Old Mar 7, 2005 | 10:38 PM
Mikey97Z's Avatar
Well when I installed the heads/cam/springs I used some new Crane lifters. Then one day I was lashing the rockers and I noticed that some lifters compressed real easy. If I can compress a lifter by hand then it must be collapsed, right?
So later I replaced them with some CompCams "High Energy" lifters which CC recommended for my cam. But the same thing has happened to a few of those lifters now too.
I'm building a new motor now, and I was considering re-using those springs because they're nice, but I just realized how strong they are and thought maybe they're wrecking my lifters.
Old Mar 8, 2005 | 01:27 AM
disco192's Avatar
As long as you are getting new lifters, get comp-r lifters. They will handle more pressure.
Old Mar 8, 2005 | 09:00 AM
Mikey97Z's Avatar
They do? I thought they just had less travel. Plus aren't people having problems with them coming apart? I think I'm going to have to use lighter springs.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Red_94Formula
Jan 22, 2015 12:17 AM
siguy
Nov 27, 2014 10:07 AM
