Starting issue or lack of
Old Jan 14, 2008 | 05:54 PM
LALT1's Avatar
My mind just is not functioning right I guess, but what is that will cause a my car to try and hit for a just a second and then never try again. the last two days it has done the same, if you don't let it sit a while it won't even try to do that. I was thinking something caused that but my mind just is not cooperating.
Thanks in advance.
Old Jan 14, 2008 | 06:10 PM
Green96Z's Avatar
Kinda confusing, but are you trying to say that it will try to crank and then not crank at all unless you let it sit for a while then try again? If so, I would say the battery might be dead. Or your starter is going out.
Old Jan 14, 2008 | 06:16 PM
LALT1's Avatar
sorry, it cracks just fine, just will not fire. I have changed my fair share of opti's,but never had one hit like this one does.
Old Jan 14, 2008 | 06:33 PM
n2ceptor's Avatar
??????? If the vehicle is cold, it will start?????? And if its warm/hot it won't???????
Old Jan 14, 2008 | 06:41 PM
LALT1's Avatar
No it will not start, just try to hit and then nothing just crank. Plenty of fuel, no fire, also security light is on while cranking and seems to be a clicking under dash I have not heard before.
Old Jan 14, 2008 | 08:31 PM
OBE1 95Z28's Avatar
Check the fuel pressure to make sure your fuel pump check valve isn't stuck open.
Old Jan 14, 2008 | 08:33 PM
LALT1's Avatar
I have a gauge on it, FP is fine, is not firing.
Old Jan 14, 2008 | 08:48 PM
kylersaulsbury's Avatar
Sounds like your vats it acting up. check shbox.com I think it says something about how to bypass it or shut it off. Or someone will chime in.
Old Jan 15, 2008 | 09:59 AM
rich152's Avatar
^^^^There you go. Try cleaning the keys contacts with alcohol first.
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Gtpguy
Jan 26, 2015 04:50 PM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
Hoodshaker
Aug 27, 2002 02:32 PM
