Starter wiring
Old May 17, 2009 | 04:31 AM
Ian marshall's Avatar
Starter wiring
On the 94 Camaro starter wiring there are 3 wires within the small loom that goes to the starter motor, battery cable, purple stater cable and one other with a ring teminal, can anybody tell what that's for and where it goes?
Old May 17, 2009 | 08:02 AM
Guest47904's Avatar
Guest
I believe it could be the ground that goes to the block above the starter.
Old May 17, 2009 | 08:21 AM
Thanks for that I'll give it a try
Old May 17, 2009 | 08:31 AM
merim123's Avatar
the big one goes to the battery.
the purple one goes back inside the car and that's connected to your vats relay.
the little ring black one gets grounded right near the starter on the block
Old May 17, 2009 | 08:47 AM
Old May 17, 2009 | 09:06 AM
Thanks for the clarification,
Old Feb 16, 2023 | 04:57 PM
TKGuarantee's Avatar
Re: Starter wiring
just looking for some clarification cause i just put the engine back in my 94 camaro.
as far as the connectors on the starter, big one on the top bolt, purple to the small bolt, and black goes from the harness to the block?
i put all 3 wires on the starter and the car gets power, but wont crank. When I trie to crank i lose all power. Pretty sure i messed up a ground somewhere.
Old Feb 16, 2023 | 05:33 PM
Re: Starter wiring
See Shoebox's clickable harness photo:
1995 Z28 A4 Engine Harness
http://shbox.com/1/harness3.jpg
The purple solenoid wire comes from the “theft deterrent relay” (TDR). That part of the Pass-Key II (VATS) system:
http://shbox.com/1/starter_charging_95.jpg
Old Feb 16, 2023 | 09:35 PM
Re: Starter wiring
Also
http://shbox.com/1/starter.jpg
http://shbox.com/1/g103.jpg
Critter
Jul 7, 2015 08:33 PM
robcarnut
Mar 20, 2015 03:40 PM
eazyZ
Mar 1, 2015 07:12 AM
ModdedNerd
Feb 5, 2015 04:37 AM
Jeff1904
Jan 3, 2015 12:00 AM
