Starter wiring
Starter wiring
On the 94 Camaro starter wiring there are 3 wires within the small loom that goes to the starter motor, battery cable, purple stater cable and one other with a ring teminal, can anybody tell what that's for and where it goes?
Re: Starter wiring
as far as the connectors on the starter, big one on the top bolt, purple to the small bolt, and black goes from the harness to the block?
i put all 3 wires on the starter and the car gets power, but wont crank. When I trie to crank i lose all power. Pretty sure i messed up a ground somewhere.
Re: Starter wiring
See Shoebox's clickable harness photo:
1995 Z28 A4 Engine Harness
http://shbox.com/1/harness3.jpg
The purple solenoid wire comes from the “theft deterrent relay” (TDR). That part of the Pass-Key II (VATS) system:
http://shbox.com/1/starter_charging_95.jpg
