Starter Relay, Pass Key Bypass
Old Dec 30, 2006 | 11:54 PM
Hawk944's Avatar
Ok, i'm not going to have the factory computer i'm going with a BS3. I wanna know if I can bypass the Pass key module and the starter relay. Can I just run the yellow wire that runs from the ignition switch to the starter soleniod to crank the starter? So since i'll have the BS3 then no vats, meaning I don't have to worry about the Pass Key. But is the starter relay worth having? Thanks
Old Dec 31, 2006 | 09:32 AM
Dave89IROC's Avatar
if you bypass the relay that way, it will start in any gear
i'll be back in a few with more info
Old Dec 31, 2006 | 09:34 AM
Dave89IROC's Avatar
ok, if you leave the relay in place, and ground the yellow/black stripe wire, the neutral safety switch will still be functional
Old Dec 31, 2006 | 11:18 AM
Hawk944's Avatar
Awesome, thanks for the help. I might be asking you which one is the yellow with the black stripe. I guess I should have said that the car i'm working on is a 93, and all of the wires are Yellow if i'm not mistaken, the 3 big ones and the little one. Thanks though.
Old Dec 31, 2006 | 12:16 PM
Dave89IROC's Avatar
I think it is the little one
Old Dec 31, 2006 | 01:47 PM
Hawk944's Avatar
Thanks, I didn't see the black stripe on the little one, the stripe was hiding to the inside. So all i have to do is to yank out the Pass Key II system and the wires, ground the little yellow wire with the black stripe and she'll start. Sounds like a good deal to me. Thanks Dave!!
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
Critter
Jul 7, 2015 08:33 PM
lildemars09
May 28, 2015 07:54 PM
Scottyboy
Feb 11, 2015 10:28 PM
Jeff1904
Jan 3, 2015 12:00 AM
