starter Question
Old Apr 22, 2004 | 10:54 AM
TrouserSnake's Avatar
starter Question
Ive got a 94.. Do I have to take the Y pipe out to get that bastage out?
Its only 2 bolts right?
Old Apr 22, 2004 | 11:14 AM
Red96Lt1's Avatar
on my 96 I didn't have to with the cats (dual cat car). I don't have to either with my ORP
My friend with a 95 6 cylinder had to though
Old Apr 22, 2004 | 11:40 AM
HBHRacing's Avatar
I ahve heard it go both ways. some you can sneak it out some have no been able too. from what I understand that size and shape of an LT4 replacment starter is able to slip in and out. you might look into that for a replacment for next time
Old Apr 23, 2004 | 08:31 PM
Mtrhds94Z's Avatar
Re: starter Question
I just went thru a nightmare with what began as the starter.. two studs on the Y pipe broke, and it went on from there..
Yes, with an A4 single cat, the Y pipe has to come off.. I even partially disassembled the starter in place [knowing the studs on Y pipe were going to break off..]
Also, these starters the solenoid does NOT come off either..
Fortunately, I had a set of shortys that I am putting on, and the flanges on those will come off a lot easier than a stock Y pipe will in future.. [no studs just 2 bolts each side]
There's 2 bolts on the starter [ and 2 wires] 3 nuts, on studs, on each side of the stock Y pipe to the stock exhaust manifolds[ and the few bolts by the cat to catback area] have fun [I sure didn't]...
Old Apr 23, 2004 | 09:23 PM
94Z28WP's Avatar
I just removed mine a couple hours ago on stock manifolds and Y-pipe... It's a pain to remove, BUT I got mine out without removing the Y-pipe... I ended up turning the starter around and getting it out that way... I couldn't get it out by just unbolting it and pulling it straight out for whatever reason... I was able to pull it out between the transmission lines and torque converter/flywheel... I had to unbolt a bracket that held the trans lines to the oil pan so I could move the lines enough to pull it out though... So it can be done that way, but it's a tight squeeze.
warmeck
Feb 5, 2015 11:04 AM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
Jeff1904
Jan 3, 2015 12:00 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
