Starter Q: (Shoebox, injuneer)
Originally posted by 1 Nasty Bird
no kidding i have yet another "design." I have 2 inverted torx bolts holding the solenoid on. Looks like the opti bolts but a tiny bit bigger. Seems like you pop those to bolts and solenoid will fall off. This is on my new starter and on the one that i just pulle dout of my car. Maybe they were both remaned by the same company??? Its just 2 bolts on the end of the solenoid opposite of where the wires are hooked too. Mines a duralast rebuild from autozone.
Wish MINE had come off with 2 bolts.. It would have saved MUCH work last month when I had to remove stock Y pipe, broke one stud off, then put headers on
rather than fight the studs... basically all from a solenoid failure[even tried to disassemble the starter motor to get it out of there with the Ypipe still on.. WOULD NOT come out with that solenoid on there, and the solenoid does NOT come off my stock LT1 starter..]
I sent Spinner pics to post maybe he hasn't gotten to that yet..
Charlie
rather than fight the studs... basically all from a solenoid failure[even tried to disassemble the starter motor to get it out of there with the Ypipe still on.. WOULD NOT come out with that solenoid on there, and the solenoid does NOT come off my stock LT1 starter..]I sent Spinner pics to post maybe he hasn't gotten to that yet..
Charlie
Ummmm is your car a T56, causing you to have to drop the Ypipe to get the starter out? Cause on my A4 95 T/A all i had to do was undo the 4 bolts holding the flywheel dust sheild off and wiggle it around the Ypipe. Went right in and out. Are T56 cars different???
If you mean me, I have an A4..
No way that was coming out [even partially disassembled, I tried that too.. I actually disassembled the 'motor' part of the starter off it.. note the purty paint in the pic..lmao still wouldnt come out]
Ypipe and trans cooler lines are in the way[and the trans cooling lines are hard to get the transmission ends off with trans in place..] Trust me it wouldn't come out, I tried everything..
Originally posted by Mtrhds94Z
Thanks Spinner, for hosting them..
Charlie
Rob, that you know of, is your starter factory original?[Mine was for sure..]
Charlie
Mine looks like this one.
Originally posted by shoebox
I am pretty confident that mine is the origninal. It is definitely a different style. I don't have any pictures with great detail of that part.
I can't believe there are so many variations of the LT1 starter, especially if they haven't been swapped or serviced/rebuilt..My first thought was that the 'removeable' solenoid ones were rebuilt at some time in the past and that's how the rebuilders take it off..[various methods..]
Rob, are you sure yours was never serviced?
Also, GM lists the housing as including the solenoid[for service] I didn't bother pricing it, since the LT4 starter was 160 shipped and new, I got that..[ the solenoid on THAT does not come off either]
Thanks!
Charlie
Wish mine would have looked like that..
Thanks!
Charlie
Thanks!
Charlie
Formula Steve
Sep 19, 2023 08:31 AM
tommalcolm
Sep 11, 2015 03:39 PM
jackpawt883
Sep 10, 2015 08:53 PM
