starter problems
Old Oct 26, 2005 | 08:48 AM
TransAmGT94's Avatar
starter problems
Just finished my engine swap and went to start it up and the starter just grinds. It catches the flywheel moves it about 6 teeth and then it grinds and catches again. It is the same starter and flywheel off my old engine. The only difference with the two is the block is out of a vette at least thats what im told. Its a four bolt lt1 block. Any ideas i was guessing it just wasnt in all the way but im not sure how it couldnt have been. The teeth on the starter a ground down from me trying to start it and pulling it off and redoing it so i have a new starter. Ideas before i fry this one? another thing that shouldnt matter is the starter bolts disapeared and i had to buy replacements they are not the exact same but it doesnt look like there is any movement.
Old Oct 26, 2005 | 04:52 PM
Re: starter problems
new starter in new starter bolts and still clicks and doesnt turn over any help?
Old Oct 26, 2005 | 04:55 PM
turbo_Z's Avatar
So it clicks or grinds? Clicking indicates a low battery.
Old Oct 26, 2005 | 05:02 PM
now its clicking but the flywheel is rotating a little an the battery starts other cars still a low battery?
Old Oct 26, 2005 | 05:08 PM
turbo_Z's Avatar
The battery may have enough amps to turn over a 4 banger but not a V8.
Old Oct 26, 2005 | 05:27 PM
Z28Nut's Avatar
With the bottom cover off the bellhousing check to see if the starter gear is coming out far enough the engage flywheel or if the teeth are too far away from it. Are there any shims between starter and block? If there are, try removing them.
Old Oct 26, 2005 | 05:41 PM
no shims im charging the battery but not looking promising the teeth are set in the flywheel and are makeing contact no slipping any more just not spinning the flywheel over enough to start it maybe a quarter of a turn on the flywheel is all im getting
Old Oct 26, 2005 | 06:06 PM
the vette starter is the same as a z28 or a ta starter right??? or am i missing something when i got up high volts it went back to grinding
Old Oct 26, 2005 | 07:16 PM
shims and more shims still no luck turns about a dozen teeth and then locks up and grinds ? any body else
Old Oct 26, 2005 | 07:45 PM
Dave89IROC's Avatar
does the engine turn over ok by hand?
Old Oct 26, 2005 | 09:13 PM
yes with heads on and plugs inhave to use a ratchet but it turns little more info its a lt4 block i think but lt1 flywheel now i triedthe lt4starter but it did nothing any other ideas
Old Oct 27, 2005 | 10:22 AM
just checked voltage on both ends battery and starter and getting right at 12 volts and nothing the lt4starter just clicks thelt1 starter turns it over a little but not enough to start it then it catches and grinds
Old Oct 28, 2005 | 10:51 AM
It started and rand last night. It ended up being a wiring issue. Sounds great cant wait till it gets broke in so i can see how it really runs.
Old Nov 3, 2005 | 04:29 PM
livin2dxtreme's Avatar
TransAmGT94; I am having the exact same problem and i was wondering if you could tell me what the exact "wiring" issue was. Your help will be greatly appreciated.
Old Nov 30, 2005 | 12:11 PM
mebanditws6's Avatar
He ended up needing a starter for a 96 Vette. The stock starter wasn't meshing correctly and seizing up.
Jason
AlaskaZ28
Apr 17, 2015 08:54 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
97z28k&N
Jan 9, 2015 04:58 AM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
Jeff1904
Jan 3, 2015 12:00 AM
