Starter problem need help IMMEDIATELLY
Old Jan 24, 2005 | 05:06 PM
jbsupra89t's Avatar
So I am changing the starter right now, was going real well, then I noticed the little wire that is secured with the 8mm nut. It snapped at the connector that holds it onto the stud. WTF am I gonna do now? Am I screwed? Help please.
-J
Old Jan 24, 2005 | 05:08 PM
camarokid24's Avatar
Re: Starter problem need help IMMEDIATELLY
Do you think you can strip the wire and put a new connector on it and put it on the stud ?
Old Jan 24, 2005 | 05:28 PM
hotrod18_69's Avatar
That would be your only option. Shouldn't be too hard.
Old Jan 24, 2005 | 05:35 PM
jbsupra89t's Avatar
Thanks, yea my buddy and I just got some from his house doing that now. Thanks hopefully it should work out, don't see why not.
-J
Old Jan 24, 2005 | 06:49 PM
Bersaglieri's Avatar
Should work find as long as its all connected well. Is this the LT4 unit your putting on? Good Luck.
-Dustin-
AlaskaZ28
Apr 17, 2015 08:54 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
97z28k&N
Jan 9, 2015 04:58 AM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
Jeff1904
Jan 3, 2015 12:00 AM
