starter install
Old May 13, 2006 | 07:31 PM
jamilz28's Avatar
starter install
how can i take the starter out and reinstall it!!!!!
Old May 13, 2006 | 07:44 PM
ABA383's Avatar
Re: wtf starter install
Disconnect a battery terminal first. Unbolt the two starter bolts, one long and one short. I have Kooks LTs so the starter slips right out. (I've heard that sometimes with shorties you have to remove the exhaust Y-pipe first.) Then remove the 2 wires connected to the starter and you're done. Reverse the order to install. Also some have shims between the starter and the block to help the starter gear mesh correctly with the flywheel/flexplate gear.
I've gotten pretty good at this over the last year as my motor was eating stock/reman LT1 starters...We'll see what happens to the LT4 in there now...
--Alan
Old May 13, 2006 | 08:32 PM
jamilz28's Avatar
so i will have to cut the y pipe off because i dont have headers
Old May 13, 2006 | 08:39 PM
matLT1's Avatar
You shouldn't have to cut the y-pipe, it unbolts and can be dropped from the car.
Old May 13, 2006 | 10:39 PM
jamilz28's Avatar
i dont have a cat an i put a welded pipe and it covered the bolts over the cats
Old May 13, 2006 | 11:22 PM
WeirdRich's Avatar
you should still be able to sneak a hand around there to take the 2 bolts out...then slide the starter towards the front of the car until you can pull it out.
Old May 13, 2006 | 11:46 PM
jamilz28's Avatar
where can i get a cheap starter
Old May 13, 2006 | 11:50 PM
Most chain parts stores can sell you a cheap, rebuilt starter (if that is what you want).
Old May 13, 2006 | 11:53 PM
jamilz28's Avatar
are they as good as new ones?
Old May 13, 2006 | 11:59 PM
bstieboydp's Avatar
probably, i got mine from aid auto for 90 bucks remaned with 2 year warranty no problems yet
Old May 15, 2006 | 03:13 PM
94_PatriotRed_Z's Avatar
Re: starter install
go to AutoZone and get on with a lifetime warranty, then you wont have to buy another one agian, I think they are around $150. I had to change my 2 weeks ago in a parking lot with a scissor jack, it wasnt to fun, but I got it done, the Pacesetters made easy acess to it
Old May 15, 2006 | 03:37 PM
SentimentalValue's Avatar
Re: starter install
When you put the new one back in and hook the two wires back up to the new starter, make sure the wires both come in from diffent directions so they won't "jump spark" across each other. If you don't, once you hook the battery back up your car will begin to start on it's own...
Nov 18, 2023 07:21 PM
lt1matt
Mar 21, 2015 07:35 PM
robcarnut
Mar 20, 2015 03:40 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
Jeff1904
Jan 3, 2015 12:00 AM
