Starter bolt broke.
Old May 19, 2006 | 12:47 AM
LT1 POWR's Avatar
Starter bolt broke.
Alright so the other day i was takeing my starter off and the bolt where the battery conects, the thicker guage wire, just broke off. So i took it out and i ended up buying a remanufactured AC delco starter with a lifetime warrenty from Oreileys. I asked them if i could just replace that bolt and they said no, then i asked if i could just replace the solenoid but noone carried one. So is there anything else i could have done or was a new starter inevitable.
Old May 19, 2006 | 12:50 AM
LT1 POWR's Avatar
Re: Starter bolt broke.
I guess i could have taken it apart or taken it to a local alternator/starter rebuilder and seen what he would have done but this is my daily driver and i didnt have time for it.
Old May 19, 2006 | 02:36 AM
Loadre's Avatar
Yup, same thing happened to me but fortunately I had time to run to a rebuilder and they put in a new solenoid in about 3 minutes and it cost next to nothing.
Old May 19, 2006 | 07:30 AM
LAB3's Avatar
Thumbs up Re: Starter bolt broke.
A lot of LT1 owners go with the LT4 starter as it is a reduction gear design that has more torque. But the solenoid does not unbolt like the older small block Chevy's. A rebuild shop in Ft. Worth told me he can replace the solenoid and they drill and tap screw hole in the solenoid case so it will mount to the starter motor. My solenoid is starting to act up ( the clicking sound when you hit the key) but after several times it finally turns over. So it is time for a fix. I like the Lifetime replacement you were talking about as I was going to have mine rebuilt.
Old May 19, 2006 | 11:52 AM
19z28camaro02's Avatar
Is the lt4 the same for install? are the internals the only difference between the lt1 and the lt4 starter?
Old May 19, 2006 | 09:19 PM
LT1 POWR's Avatar
I also asked about an LT4 starter but they said that they dont carry them anymore and i would have to get it at the dealer.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
thenewkid
Nov 18, 2014 12:57 PM
1LEThumper
Jul 14, 2003 12:45 PM
