starter?
Old Aug 22, 2008 | 04:42 PM
aidens z's Avatar
starter?
hello,1st post here.after motor rebuild one day car wouldnt start, all id get was kind of a vroom sound coming from the starter. A buddy of mine beat on the starter and it eventually started so i replaced starter and that worked fine for about 3 weeks.Yesterday i go to start car and same thing,just a kinda vroom sound coming from starter no clicking.Think i just got a bad starter from pepboys?
Old Aug 22, 2008 | 04:51 PM
BUBBA's Avatar
Kinda sounds like it. Probably a rebuilt eh? If you have juice to the solenoid and the starter spins but doesn't engage the fywheel, either it doesn't fit right or the bendix is boogered. JMHO I would contact a starter shop and ask their opinion based on your observation.
Old Aug 22, 2008 | 05:03 PM
BUBBA's Avatar
Also: are you certain that you did not damage a tooth or two on the flywheel during the rebuild/install. If the fywheel has damaged teeth and the starter gear happens to stop opposite that damaged area, the starter would not engage the wheel at that point. You might test this by turning the engine over by hand or pushing it a bit and see if the starter will engage at some other point (s) on the flywheel. Food for thought.
Old Aug 22, 2008 | 05:15 PM
Green96Z's Avatar
+1 for checking the flywheel teeth. Did you make sure the starter was shimmed right?
Old Aug 22, 2008 | 07:22 PM
aidens z's Avatar
there was no shimms on the original when i took it off nothing fell out so i assumed i didnt need any
Formula Steve
Sep 19, 2023 08:31 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
4586
Aug 18, 2015 07:08 AM
realistyc
Jul 28, 2015 07:32 PM
