starter?
Old Apr 29, 2004 | 11:10 AM
ReptileZ28's Avatar
starter?
dumb question but how many wires go on the starter and which pole does each attach to? i took the engine out in august and can't remember
Old Apr 29, 2004 | 11:14 AM
HBHRacing's Avatar
it grounds through the block
has a large hot wire
and then a small hot wire to the seliniod.
as for which poles they go to you should only have one large stud for the hot feed and possibly 2 that could be the selinoid wire. so to compeleatly answer your question ou might need some other imput
Old Apr 29, 2004 | 11:16 AM
ReptileZ28's Avatar
i have the large hot wire but i have 2 small wires. do both the small wires go on the same stud ( thanks for the reply )
Old Apr 29, 2004 | 11:18 AM
HBHRacing's Avatar
that i'm not sure. I was only aware of one. perhaps teh other isa fusable link? i'll do some cheking
Old Apr 29, 2004 | 11:21 AM
ReptileZ28's Avatar
thanks
Old Apr 29, 2004 | 11:22 AM
Mike383LT1's Avatar
starter
one wire is the hot goes right to the starter the two small wires the heavier of the two goes to the starter selinoid the other gets grounded to the block do not i repeat do not put the two small wires together on the same stud on the selinoid you will get a fire.
Old Apr 29, 2004 | 11:35 AM
ReptileZ28's Avatar
thanks for the help. you guys are awsome
Old Apr 29, 2004 | 02:06 PM
ReptileZ28's Avatar
any idea waht the ground is to?? thanks for all replies.
-mike
Old Apr 29, 2004 | 02:11 PM
HBHRacing's Avatar
this one is close to the starter http://shbox.com/1/battery_cable_ground.jpg
I'm not sure if thats the only one or not
Old Apr 29, 2004 | 02:34 PM
ru2slo_99's Avatar
I think that is a ground for the computer. The ground wire goes on a bolt that is by the bolt for the dipstick.
Formula Steve
Sep 19, 2023 08:31 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
4586
Aug 18, 2015 07:08 AM
realistyc
Jul 28, 2015 07:32 PM
