Started my 383 Up
Old Mar 15, 2006 | 05:02 PM
  #16
3gc's Avatar
3gc
Re: Started my 383 Up
I actually removed the oil pan with the engine in the car on monday because i'm retarded and thought the oil pump driveshaft went in from the top. Having a hoist helps that out alot. Took a total of two hours start to finish. It didn't sound like it was coming from the pan. I clearanced the pan with the engine on the stand so it should be good. But since I have it torn apart already and the seal i had to order probably won't get here until friday, I might as well check the pan out tomorrow too, for peace of mind.
Here's what the timing cover looked like when I pulled it off. -The scratches
Then After Clearancing again
I sitll don't understand how it only did it at a certain RPM but hopefully this was the problem.
Old Mar 15, 2006 | 05:40 PM
  #17
IllusionalTA's Avatar
Diff load's at certain rpm's.. You still might have it.. Who know's.. hopefully you got it taken care of.. My motor will be broken in on a dyno prior to install.. none of this in the car crap..
cheapchevy
Apr 8, 2015 08:48 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
