Stalling Problem??
Old Jun 20, 2011 | 09:46 PM
DarkKnight's Avatar
Stalling Problem??
Ok, so recently, every once in a while, I'll be driving down the road and my engine cuts out with no warning. It just dies as Im driving. I coast to the side of the road. Wait a minute or less, car starts up after a turn or two and runs fine and it wont happen again for a while. Could be days or weeks and it will do the same thing. Anyone encounter this or even have a clue? Thanks.
Old Jun 20, 2011 | 10:30 PM
94Z28LS1toLT1's Avatar
Re: Stalling Problem??
could be bad coil,i would scan it to see whats going on for codes wise
Old Jun 20, 2011 | 11:17 PM
mrmint69's Avatar
I had the exact same thing happen before. I changed the ignition switch and it has been fine ever since. Sometimes it would sputter and stay running, so you might have another problem. My GMC jimmy use do that and the fuel pump went out just a little while after it started.
Old Jun 20, 2011 | 11:26 PM
You need to provide basic info about the car - year, model, engine, trans and any major mods. Use the "Signature" feature. That way people can help you without asking basic questions. Not all years of the LT1 are the same.
Scan it, check the fuel pressure.
Old Jun 21, 2011 | 08:31 AM
rocknroler69's Avatar
I am having a similar problem in my 93, except I need to wait an hour or so for it to start again, originally I was told to replace my fuel pump, I did, and the problem continued, still trying to figure it out
Old Jun 21, 2011 | 10:56 PM
DarkKnight's Avatar
Sorry, its a 1994 with an A4. 383 stroker. The fuel pump is a brand new Walbro.
Old Jun 22, 2011 | 05:25 AM
Pump may be "brand new", but did you check the fuel pressure?
Old Jun 22, 2011 | 01:54 PM
DarkKnight's Avatar
It reads about 43-44psi
Old Jul 9, 2011 | 05:53 PM
darkheart69's Avatar
im having the same problem in my 93 camaro z28. it stalls at least once a day. also my rpm gauge isn't moving but all other gauges work fine.
Old Jul 9, 2011 | 08:47 PM
mrmint69's Avatar
You should start your own post and give a little history on your car and what you have tried so far. I listed my solution earlier in this post. Not guaranteed to be the fix, but worked for me.
james007moore
Jan 1, 2016 01:14 PM
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
greenzee28
Mar 26, 2015 09:13 AM
marine1bird
10
Jan 25, 2015 12:02 AM
edxiel
Jan 24, 2015 07:40 PM
