Ss Led 3rd Brake Light
Old Feb 29, 2004 | 09:59 PM
SiDeWaYZz28's Avatar
Question Ss Led 3rd Brake Light
hey whats up folks i just put a 01 ss spoiler on my car and i plugged in the brake light now it says ABS INOP light is on..
im shure its because i need a resistor..my question is how many ohms is it??thanks
Old Feb 29, 2004 | 10:08 PM
Brandon94Z28's Avatar
My old 94 did the exact same thing. I took the old bulb off of my stock spolier and spliced inline into the new wiring harness. It's hard to explain but I used both the LED and the stock bulb. I just tucked the stock bulb into the spoiler under the plastic cover. It tricked the car into think the stock spoiler was there. After that my abs inop light went off and my cruise control worked.
I know this is confusing but hopefully you can understand what I am trying to say.
Old Feb 29, 2004 | 11:30 PM
thanks i might have to do something like that
Old Mar 1, 2004 | 10:41 AM
My Mighty White 95 Z28's Avatar
Cool
You can also wire in a relay. That is what I did and it works prefectly.
Old Mar 1, 2004 | 12:02 PM
thanks for the input
Old Mar 1, 2004 | 12:20 PM
350 HRSS's Avatar
I had to do this as well. Just run one of your old bulbs in series with the wiring harness, and tuck it underneath the plastic.
W/ the ABS inop light on, your cruise control won't work either.
PITA
Old Mar 1, 2004 | 03:43 PM
so im suppose to splice in the old brake light too??
Old Mar 1, 2004 | 05:16 PM
LanceJoker's Avatar
Did you guys splice wire to wire or put the harness in between the two.I used the stock harness to wire in the LED brake light on my SS spoiler.No lights,and everything works fine.
Old Mar 1, 2004 | 09:44 PM
bump up
Old Mar 2, 2004 | 12:45 AM
Steve in Seattle's Avatar
Thumbs down
lol... and when the bulb wired in line burns out you the ABS inop again.
Get a 2k ohm resistor and wire it inline with the LEDs.
Old Mar 2, 2004 | 01:00 AM
thank you very much thats the way i wanted to go...is that what u did?
Old Mar 2, 2004 | 06:15 AM
RE AND CHERYL's Avatar
The reason the light comes on is because the system measures resistence in the circut to make sure the bulb is good. The LED lights have next to no resistence so the system gets a little confused. Install a 1/2 watt resistor and your problems will be gone for good. The relay idea is also good but the light bulb idea is a little out there.
Old Mar 2, 2004 | 10:59 AM
thank you so i should use 1/2 watt resistor??
dluna333
15
Mar 13, 2015 12:30 PM
WildRidez
Feb 23, 2015 07:24 PM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
