SS brake light question
Old Jun 24, 2004 | 10:13 AM
RE AND CHERYL's Avatar
I installed a late model SS spoiler on my 94 Z28 and got the ABS fault light like many of us found out. Several people sugested installing a resistor to fool the computer. I did that and it worked but the resistor gets hot as hell and it worries me. I installed a 1 watt 10 ohm resistor.
Did this happen to any one else? What did you do about it? What size resistor did you use?
Thanx
Old Jun 24, 2004 | 12:21 PM
Use a relay. It is heavy duty enough to dissipate the heat. Bridge your two leads to 85 and 86 of the relay.
Old Jun 24, 2004 | 02:46 PM
JDBlaze85's Avatar
ive converted to a ss wing before and never got the abs light? just hook up the new brake light wiring.
Old Jun 24, 2004 | 07:25 PM
CamaroSS30thAnn's Avatar
^^^^ like he said if ur wirings not hooked up ..hook it up......ive hear cases where if the wiring not hookedd up it will trip the light
Old Jun 25, 2004 | 04:59 AM
slopokrodrigez's Avatar
I just put mine on and DID wire it and I got the same problem. It's because the light uses led's and not bulbs. The PCM is looking for a resistance from a bulb filament. A resistor is ok but you'll be droping a lot of voltage and not giving the led's the full 12 volts. The best way to fix it is like Rob said with a relay. The coil of the relay will act like the filament of the bulb when the led is not on.
BTW when I called RK Sports about the problem, they said they never heard of it and no one had the problem in the past
Old Jun 25, 2004 | 08:08 AM
Another reason to stay away from those pirates. Sheesh.
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
AW/whiteZ-28
Aug 27, 2002 12:53 AM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
