squeal or screech when turning.....
Old Jan 2, 2004 | 03:13 PM
  #16
Hyperspeed97z28's Avatar
Originally posted by WhiteBeast
I have the exact same problem....When i do turn the wheels to the left a loud squel coming from the left front wheel. I replaced the brake rotors thinking that was the problem but no go. So now im thinking it might be the brake pads, even though they look good.
I also noticed that one of my wheel studs was broken off. But it is only the tip that is broken off. The stud is still good but i think this could be a possibility.
If you find out what is causing your problem please let me know.
my noise is from the REAR... I think were having different noises...
Old Jan 3, 2004 | 02:18 AM
  #17
bunker's Avatar
Sorry didn't see the post, yeah its the C-clips, I think the part number is 344171, its called a axel shaft lock, prevents the shaft from moving in & out. & I think thats the part number, enjoy.
Matt.
Old Jan 3, 2004 | 10:55 AM
  #18
Matt,
Is 344171 the GM part # ??
Old Jan 3, 2004 | 11:33 AM
  #19
KeVMaN's Avatar
I was having this problem and it went away when I changed my rear end fluid
Old Jan 3, 2004 | 02:59 PM
  #20
bunker's Avatar
344171 Yep just called GM for ya it shows up as the part. Its $3 retail each, I would change both of them while you are there..
Old Jan 3, 2004 | 03:48 PM
  #21
Thank you very much!
1 bottle of the rear end additive is good when I put it back together? and what weight fluid do you reccomend?
Old Jan 3, 2004 | 11:06 PM
  #22
Brandon94Z28's Avatar
It sounds to me like it is your rear end... Mine did the exact same thing and then I changed the fluid and put the limited slip additive in and whallla... noise gone.
good luck
Brandon
Old Jan 4, 2004 | 08:21 AM
  #23
I hope it isnt the rear end... I'll be pissed off. I just bought it for 200 bux off Jason Short and he assured me it was ready to be bolted in... if it were the rear end why would it only do it going left? We'll see what happens after I replace the C-Clips and check the brakes on the left side....
Old Jan 4, 2004 | 03:59 PM
  #24
BigJustinZ28's Avatar
mine did that after me and a buddy went in to fix the rear (turned out the be a bad pinion bearing). Put it all back together and it started sqealing when I turn left about 50% of the time. Its annoying as hell. I could have sworn it sounded like it was coming from the brakes. I have no way of checking right now tho cuz I blew the rear up again. Apparently I missed something :/ . Let me know when you find out for sure what it is , because I cant really play with mine right now lol.
colts0455
Jul 7, 2015 07:19 PM
ryan75
Sep 1, 2003 05:43 PM
93RedDevilZ28
May 17, 2003 10:06 AM
djgerry
Mar 9, 2003 08:53 PM
mosskeet
Mar 5, 2003 09:34 PM
