Alternator "squealing"
Old Sep 1, 2003 | 03:39 PM
ryan75's Avatar
This is actually on my wife's Grand Prix, but...the car started squealing really bad when I cranked it. I took the belt off and turned all the pulleys, and the alternator pulley would make a squealing sound. I checked the voltage at the alternator and it is 14.3 or so volts, so that should be okay. Is this "squeal" an indicator or does the alternator need lubricated or something? How can I fix this?confused:
Old Sep 1, 2003 | 03:48 PM
TobyZ28's Avatar
did you get oil on the belt? That would cause a squeel under load..
Old Sep 1, 2003 | 04:49 PM
ryan75's Avatar
No, the belt is fine. I carefully inpected it after removal.
Old Sep 1, 2003 | 05:18 PM
RamAir95TA's Avatar
Squealing from the alternator is a good sign that the shaft support bearings are going. It might still read good voltage, but it's life is coming to an end.
Old Sep 1, 2003 | 05:43 PM
1EVILZ's Avatar
Wiggle the pulley up and down and see if there is any play to the bearing. If there is, your bearings in the main shaft are going oval. This could cause the alternator to seize solid after a prolonged period of time.
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
Thirim
Jul 30, 2015 01:29 PM
