sputtering
Old Apr 12, 2007 | 10:24 PM
rexcellent's Avatar
sputtering
about 2 years ago my 93 Z28 started sputtering some at high RPMs, about 4000 and above. I took apart the optispark and cleaned it up good and put it back on because Im a cheap @ss and didnt want to buy a new one at the time. Car ran fine up until now. Sputtering above 4000. I'm guessing it's the same problem as before? Anyone have any other possible causes of this? If it is the opti, is the extra money worth it for an aftermarket one or should I stick w/ OEM?
Old Apr 12, 2007 | 10:36 PM
zlighting's Avatar
Sputtering? Yes, that could very likley be the optispark.... however first see if you can pull a trouble code.
For less that $240.00, install a new GM optispark, the cap and rotor wear the same as aftermarket units.
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
