Cloyes timing chail
Old Apr 12, 2007 | 07:23 PM
lt1chevelle's Avatar
Cloyes timing chail
just want to make sure iam right on this. i have a 95 with an ew iam running the gm847 cam if i get a 89+ Cloyes double roller chain it will work but might requier some grinding on the cover or a spacer? i heard someone talking about someone makes a bigger timing chain cover gasket that will help the clearence issues out?
Old Apr 12, 2007 | 08:16 PM
aboatguy's Avatar
I'm running a double roller on my 95 Vette with no clearance issues.
Mike
Old Apr 12, 2007 | 09:33 PM
The Cloyes 9-3145 is strong and inexpensive. Not everyone seems to have the same clearance issues. Just mock it up and find out what needs to be taken off the inside of the cover. Most people say it is not much.
Old Apr 12, 2007 | 10:49 PM
seawolf06's Avatar
It isn't much, mostly around the top. Put some grease on the chain and then rotate the motor over and clearance where it rubs on the cover.
Sergio
Jan 27, 2016 04:27 PM
Feffman
Oct 9, 2015 05:42 AM
chuyz28
Jan 15, 2015 04:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
