sputter
Old Jan 28, 2003 | 04:25 PM
OffspringZ28's Avatar
sputter
i put car in 6th and at about 1k-2k rpm at half throttle is sputters horrendously and shakes the whole car. it also seems to do this in other gears as well until i give it more than 75% throttle. what gives, anywho, i got the car scanned and everything checks out ok, its just that im running EXTREMELY rich. i also know that i have an exhaust leak and a slight leak in my intake elbow. im stumped, you name it ive replaced it. somebody, anybody?
Old Jan 28, 2003 | 05:37 PM
Greasepunk's Avatar
Do you feel it in the stick, like its coming from the driveline or just from the engine?
Old Jan 28, 2003 | 06:23 PM
zslates's Avatar
sounds like a common problem that most of us have. Problem is that it could be so many things. I think your o2's might be bad. Do a search for "miss" or "low rpm" in the lt1 section. There numerous posts on it.
Zack S.
Old Jan 29, 2003 | 09:30 AM
I have done the search and i have brand new 02's. Like i said, i ve replaced basically everything.would a torn elbow and exhaust leak be able to cause this?
Old Jan 29, 2003 | 02:09 PM
Greasepunk's Avatar
Yeah the torn elbow will, I thought you had already replaced it though. It's easy to diagnos, just tape up the cracked area really well with some electrical tape and then go do a test drive.
Old Jan 29, 2003 | 02:54 PM
Gripenfelter's Avatar
Torn elbow.
Bad MAF.
Bad MAP.
Bad TPS.
These are some of the causes of the low rpm miss.
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
