spun hub while re-installing. problem?
Old Apr 21, 2004 | 07:38 AM
30thannZ28's Avatar
alright guys, this is my final post about my $%!$# crank hub. I got it installed, but I used a threaded rod against some washers and a really tough piece of pvc pipe. what happened is this: as I was getting really close to finishing up, I noticed that the hub "slipped" around a little and the white mark is no longer at 12 'o clock like it was when I started. How bad is this? Does this have any effect on timing or a negative effect on the balancer? I just don't want to take the hub off again. Does this also mean my hub will spin on the end of the crank?? thanks
Old Apr 21, 2004 | 08:06 AM
simple's Avatar
the crank hub is not keyed, so if slipping is going to occur its gonna happen no matter how its put on there, altho i dont think there would be a problem with that, its a pretty tight press fit!
the only adverse affect i can think it will have is the pulley will not be lined up the way it was when taken off and might be out of balance a bit.
mine did the same thing (not much but a little bit) i just tried my best to keep at as lined up as possible and hope for the best
EDIT: havent followed your other hub posts but did you use the pre '96 hub (longer)?
Old Apr 21, 2004 | 08:20 AM
30thannZ28's Avatar
nah, I reused the stock 97 hub like an idiot.
Old Apr 21, 2004 | 08:33 AM
If the whole crank turned (most likely) and not just the hub, you are ok. It would be still lined up properly.
Old Apr 21, 2004 | 08:37 AM
rocmemphis's Avatar
The hub goes on the crank so tightly that I don't see how it would spin w/o the crank spinning also.
Old Apr 21, 2004 | 09:46 AM
30thannZ28's Avatar
yeah, I think/hope you are right. I'm just a paranoid perfectionist.
1996LT1Z28
Apr 14, 2015 07:15 PM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
1LEThumper
Jul 14, 2003 12:45 PM
